1983 T25 Passenger seat stuck - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Tech Forums > Engineering Tech
Engineering Tech A Q & A Forum devoted to Engineering Issues that don't necessarily fall into Aircooled or Watercooled Tech. Got a problem? Or an engineering question? Even a buildings or property engineering question? Then ask in here. Please, no 'For Sale' or 'Want To Buy' ads, plugs for your 'business', links to 'for sale' ads or Ebay links to your (or your mate's) auction (use the VZi 'Classifieds' section) - this also includes thinly veiled 'What's My Car Worth?' threads and "Who Can Sell Me A . . ." posts.
Old 17-02-2020, 06:03 PM   #1
Schnipps
Default 1983 T25 Passenger seat stuck
Time to take off the front seats, have a good clean underneath and maybe install a leisure battery and bigger amp. Problem: Passenger seat is completely stuck in the rails. I've had a feel underneath and pushed up both sides of the lever than holds the seat in the runners & ensured that the catch behind the seat level is up...nothing. Any advice on "unsticking" the seat would be greatly appreciated. Thanks.
Schnipps is offline   Reply With Quote
Old 19-02-2020, 07:15 PM   #2
Sol Ford
Sol Ford's Avatar
Mine had plastic covers/inserts on the tracks. Have they been broken off and part of them jammed?
Otherwise, a load of degreaser, then a hammer and a bolster chisel. Not as drastic as it sounds, put the chisel on the back of each sliding rail, you'll get a better connection and tap them alternately.
Sol Ford is offline   Reply With Quote
Old 20-02-2020, 08:45 AM   #3
Schnipps
Thanks for your reply.
Yep, plastic covers still exist.... thankfully. What I have found with the drivers-side rails is that they were somewhat warped so I would imagine that the passengers is the same or worse.
Will apply liberal amounts of degreaser and "encouragement".
Old 24-02-2020, 05:34 PM   #4
Sol Ford
Sol Ford's Avatar
Did it work?
Old 24-02-2020, 09:31 PM   #5
Schnipps
Away for work at the moment, but have some bus time scheduled in for Wednesday night. Will report back.
Old 25-02-2020, 09:32 AM   #6
Sol Ford
Sol Ford's Avatar
Just a thought. Try a block of wood, a length of 3x2 would be fine, instead of the chisel. There's less likelihood of you damaging the seat rails with wood.
Old 25-02-2020, 03:44 PM   #7
Schnipps
You mean a block of wood similar in size to something that can be used to pry apart brake callipers? Good idea!
Old 23-03-2020, 01:16 PM   #8
Schnipps
Completely forgot to say: I got the seat off. What was causing it to stick? Answer: Mud. It looked like the previous owner had taken just the left rail of the passenger seat off-roading and then not cleaned it before putting it back in the van and then putting the seat on. Weirdness! Anyway, cleaned up and all good.
Thanks for the help and support.
Old 24-03-2020, 07:15 PM   #9
The ones on my caravelle are stuck with sand and dog hair.
1970 1300 resto here
1970 1300 part 2
1988 Caravelle CL
Old 30-03-2020, 07:38 AM   #10
Sol Ford
Sol Ford's Avatar
You can't beat a bigger hammer.
