Stupid tyre size question - VW Forum - VZi, Europe's largest VW, community and sales
Old 09-06-2016, 07:18 AM   #1
FunkyDad
FunkyDad's Avatar
Default Stupid tyre size question
Sorry to sound a bit thick here.
What is the tyre hight out of these numbers please and what do the others mean.
And is it all in inches?
215/60/R17
Cheers all.
Originally Posted by kiwigirl View Post
Are you holding monkeys in clothes?
FunkyDad is offline   Reply With Quote
Old 09-06-2016, 07:27 AM   #2
StuF
StuF's Avatar
So 215/60/R/17
is 215mm wide, 60 profile/sidewall, radial construction and 17 inches
Where Napoleons armies marched with horse and musket and Hitlers Reich crumbled in blood and rubble, the warriors of Armageddon do battle against the landscape of hell now indeed thrive the ARMOURERS
Weekend - 1970 Type 2 EJ25 Powered 5 Speed EarlyBay on BTR's
Fun - Silver Porsche 996 Turbo
Inclement - Silver Porsche Cayenne Turbo S
StuF is offline   Reply With Quote
Old 09-06-2016, 07:33 AM   #3
FunkyDad
FunkyDad's Avatar
Originally Posted by StuF View Post
So 215/60/R/17
So the 60/65 (do you knock off the 5?) is from the edge of the wheel to the hight of the tread?
Old 09-06-2016, 07:50 AM   #4
roly
roly's Avatar
No, I don't know why they put picture of 65 profile but then was writing 60.
This measurement is a percentage of the width, so the sidewall height of the pictured tyre is 65% of 205mm.
roly is offline   Reply With Quote
Old 09-06-2016, 08:31 AM   #5
FunkyDad
FunkyDad's Avatar
Ok cheers.
The car we are buying comes with 255/40/R20 but the model down the range comes with 235/55/R18 and I am wondering if we could change the wheels and tyres to this, or would there be something else in the car which would be set up for the lower profile apart from the suspension.
Old 09-06-2016, 09:39 AM   #6
schmeil1
schmeil1's Avatar
VZi Member Sponsor
What's your thinking Steve?
More economy? Lower cost of replacement tyres??
This is a useful online Tyre comparison tool:
Tyre Size Calculator
As you can see very little difference between 255/40/20 and 235/55/18...
Still not driving my Buggy (though now taxed), but my 1302 is now fixed and taxed and I've now taken delivery done over 70,000 miles in my 2016 Tiguan
schmeil1 is offline   Reply With Quote
Old 09-06-2016, 09:57 AM   #7
FunkyDad
FunkyDad's Avatar
Kerbing "She" as well as price.
On our QQ we havent had one single problem.
I have found this excellent site which gives you loads of info on tyres. there is also a calculator near the bottom of this page to tell you the difference in speedo readings.
I would like to go from the
255/40/R20 to 235/55/R18
Enter the figures into it to show you the difference.
If the speedo was showing 70 I would in fact be doing 70.36
http://www.carbibles.com/tyre_bible_pg4.html
Old 09-06-2016, 11:17 AM   #8
schmeil1
schmeil1's Avatar
VZi Member Sponsor
I've used the carbible site in the past I'm at work at the moment though and couldn't remember what it was called
...and I must admit that I kerbed a front wheel on the Golf only the other day (not concentrating, don't ask ) but no longer my problem as it will be going back in only five weeks time!!
P.S. Watch the Speed Camera's with all that extra (0.36) speed
Old 09-06-2016, 12:38 PM   #9
Beetlebank
Beetlebank's Avatar
No. The '60' in this case is the height of the tyre as a percentage of its width, so with a 215mm wide/60% profile R17" diameter tyre, the sidewall height is 60% of 215mm, or 129mm. R17 means 17 inches diameter rim fitting.
Note that the 'rolling radius' (the radius of the tyre under load) will be less than the theoretical dimension due to carcass deflection and also varies with tyre pressure. The sidewall compression (and therefore rolling radius reduction) becomes less, relatively, as the profile becomes smaller.
Cheers, Carl.
One cannot reason someone out of a position they did not reason themselves into.
Beetlebank is offline   Reply With Quote
Old 09-06-2016, 01:54 PM   #10
FunkyDad
FunkyDad's Avatar
Cheers, Carl.
Without going back into the showroom and having another look, what I am basically trying to find out is how much taller in inches is the sidewall of the tyre, actual tyre showing from the wheel to the tread.
The tyres which come with the car are 40 but the lesser model comes with 55, so Im looking for more ground clearance.
so how much taller are the two tyres compared to each other.. Just as sake of argument, one is 12" high the other 15"
I think its easier to just pop back to the dealer and have a butchers
Rate This Thread:
