Breathing life in 1600tp - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Old 09-03-2017, 03:49 PM   #11
kiwitodd
Hi guys
Again another question
Exhausts,
BAS
CSP
VINTAGE SPEED
all using heaters
Anyone has experience with these??
kiwitodd is offline   Reply With Quote
Old 09-03-2017, 04:05 PM   #12
kiwitodd
Also
Vintage speed or bug-tech shifter, going with something a little different
Anyone used them?
Old 10-03-2017, 11:13 AM   #13
kiwitodd
Anyone???
Old 10-03-2017, 05:55 PM   #14
type3
type3's Avatar
Trading feedback: (10)
I have a BAS dual silencer exhaust so a bit different as there's no heat exchangers.
That aside, it's the best quality system that I've ever fitted. Being stainless too means it'll last a lifetime.
type3 is online now   Reply With Quote
Old 10-03-2017, 07:58 PM   #15
kiwitodd
Thanks for the recommendation ��
Old 15-03-2017, 01:46 PM   #16
kiwitodd
1.25 rockers
Twin dells
..... exhaust
Electronic ignition
Then, rolling road
Old 16-03-2017, 07:58 PM   #17
M.I.B
I really must get out more
M.I.B's Avatar
Originally Posted by kiwitodd View Post
1.25 rockers
Twin dells
..... exhaust
Electronic ignition
Then, rolling road
Port the stock heads and you are on the money with that choice.
'59 fully plastic bodied Wizard 2 seat roadster
Indian Scout 101ci
Originally Posted by mr slug:
"Best bike on the thread IMO, outright winner"
The Runaway Boy
M.I.B is offline   Reply With Quote
Old 20-03-2017, 11:05 AM   #18
kiwitodd
Old 20-03-2017, 02:39 PM   #19
judgie
judgie's Avatar
Trading feedback: (4)
port heads and match inlet manifolds, 3 angle valve seat cut. poss flycut the heads to bump the c/r up. cam and valve springs. 8 dowl the flywheel/crank.
if it's going to be used hard on the road then i would fit a deep sump and prob a windage tray in the case as oil surge while cornering can be a real engine killer.
Doubt you will need a extra cooler on a road car but full flow is a must so you can fit a proper oil filter. A stock size oil pump will be more than up to the task.
If you really want to go for it with stock compents , polish the rods once they all wiegh the same, match the weights of the pistons.
you need to match all the parts , no point in fitting a cam that lifts to .500" if the heads run out of flow at .450" lift. same with carbs and exhaust, i see it all the time. carbs and exhaust far to big for the engine.
Power is nothing with out control, to control your power www.rnjmotorsport.co.uk
Northampton based speed shop
01327 830400
[email protected]
judgie is offline   Reply With Quote
Old 24-03-2017, 07:48 AM   #20
kiwitodd
What rockers have people got/recommend, 1.25?
Rate This Thread:
