Breathing life in 1600tp - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Old 24-03-2017, 07:53 AM   #21
kiwitodd
Originally Posted by judgie View Post
port heads and match inlet manifolds, 3 angle valve seat cut. poss flycut the heads to bump the c/r up. cam and valve springs. 8 dowl the flywheel/crank.
if it's going to be used hard on the road then i would fit a deep sump and prob a windage tray in the case as oil surge while cornering can be a real engine killer.
Doubt you will need a extra cooler on a road car but full flow is a must so you can fit a proper oil filter. A stock size oil pump will be more than up to the task.
If you really want to go for it with stock compents , polish the rods once they all wiegh the same, match the weights of the pistons.
you need to match all the parts , no point in fitting a cam that lifts to .500" if the heads run out of flow at .450" lift. same with carbs and exhaust, i see it all the time. carbs and exhaust far to big for the engine.
Just looking to future proof first
Twin carbs
P/p heads & matched manifolds
1.25 rockers
BAS exhaust with heaters
Then look at possible cc increase
kiwitodd is offline   Reply With Quote
Old 07-12-2018, 12:06 PM   #22
kiwitodd
Hi
Silly question
What’s the difference between the 009 and SVDA distributior?
Would swapping them make any difference??
Old 07-12-2018, 12:07 PM   #23
kiwitodd
Sorry
Also
Accuspark, petronix??
Just a big difference and was wondering if one is better than the other or not
Thanks again
Rate This Thread:
