Sweep floor turbo build :D - VW Forum - VZi, Europe's largest VW, community and sales
Old 19-01-2019, 08:25 PM   #1
Rodeorayman
Rodeorayman's Avatar
Default Sweep floor turbo build :D
Hi folks,
Thought I'd do a thread and see what can be done on a tight budget with parts I have lying around.
The engine will be built using almost entirely of used parts with the exception of bearings gaskets etc
It will be race only so I am not held back by the restraints of cooling systems or pump gas and maximum power will be the aim.
I will where possible fabricate parts like the header and intake system for example in order to try and keep costs to a minimum.
The aim is to see what can be achieved without just opening up your wallet , that said nothing is free however I will publish costs.
This will be a long term project done in between jobs, racing and family so may take a while but id like to be testing the engine early 2020.
Jay
69 Bay Deluxe [email protected]
www.bjsspeedshop.co.uk
Rodeorayman is offline   Reply With Quote
Old 19-01-2019, 10:55 PM   #2
Rodeorayman
So far the list of parts I have are as follows:
Used autolinea case cut for 94mm barrels, full flow oiling.
(not a supercase so isn't shuffle pinned etc) has 1mmline bore std thrust.
Genuine vw 69mm crank used but never ground will need a polish up and measure.
8 dowel forged chromo flywheel (used)
Webcam 86b with cb cam followers all used but serviceable. (undecided on this at the mo but its here so may well use it)
Genuine VW 043 heads will need full rebuild and LOTS of port and chamber work, also will upgrade valves and springs etc but do plan to keep stock size valves at the mo.
Schadek 30mm oil pump plugged for full flow (used)
Scat power pulley.
I plan to source:
92mm forged pistons and some thick wall barrels.
Straight cut cam gears
8mm head studs
1.4:1 ratio rockers
Pushrods Steel (I have some used already cut to length however they may not work depending on the rest of my valvetrain)
Everything will be sourced good second hand where possible
Old 22-01-2019, 01:49 PM   #3
runningmonkey
I really must get out more
runningmonkey's Avatar
Interesting! Can't wait to see this develop.
My 1956 Oval Drag beetle Little Horus -
https://www.volkszone.com/VZi/showthread.php?t=1189194
runningmonkey is offline   Reply With Quote
Old 24-01-2019, 09:32 PM   #4
M.I.B
M.I.B's Avatar
Go for it. I did this once on a 1914.
Interesting results - i threw it together and didn't calc CR. - it was about 6:1 and the plugs sooted up every 100 miles or less.
But when i had time I took it out, CR'd it, had the barrels machined accordingly and it was a bombproof rocket mote in the end. Made nearly the same numbers as my 2165 big ticket motor made by a "name" from Up North.
Take your time, stick to your principles of lo-buck and you can really be surprised with the results if you take the time to put it together properly.
'59 fully plastic bodied Wizard 2 seat roadster
Indian Scout 101ci
Originally Posted by mr slug:
"Best bike on the thread IMO, outright winner"
The Runaway Boy
M.I.B is offline   Reply With Quote
Old 10-02-2019, 11:04 AM   #5
Rodeorayman
Had a look through to find some of the parts I plan to use, case looking good to use but one of the 043 heads has a spark plug insert which has now come out so will probably hunt through my old parts and see if I can find a better one.
Also found a stage two kennedy clutch
ID:	260385   Click image for larger version
ID:	260387   Click image for larger version
Old 10-02-2019, 11:17 AM   #6
Rodeorayman
Inspiration
Old 16-02-2019, 10:10 PM   #7
Rodeorayman
Managed to find a bit of time this week to sort through my cylinder head stash and found three good 040 heads that I can use for the build, I stripped them and removed all studs and they are now soaking in the parts washer.
Next week I have my parts washer company coming round to demo some other cleaning solutions including an ultrasonic cleaning tank so hopefully I'll test it out on these
ID:	260537   Click image for larger version
ID:	260539   Click image for larger version
ID:	260541   Click image for larger version
Old 16-02-2019, 10:26 PM   #8
Rodeorayman
Also I dug out the crank and flywheel I plan to use. the crank is std at the mo but looks like it may need a grind but ill try and polish it first then measure it up, if ok ill drill it for 8 dowel.
The flywheel has seen some action before but will live again, a few years back this flywheel ripped through 8 dowel pins on my cheapo Chinese crank as I launched hard
Still I have since cleaned up the damage and it runs true when bolted up to a crank.
Now onto the extra lightnening….
The flywheel started at 13lbs, I'll take as much weight as I can off of this, coupled with the light non c/w crank it will make for a snappy little engine that revs/builds boost fast.
I made a start on this but then broke my cutter will finish it up when I get some time and a new cutter.
ID:	260545   Click image for larger version
ID:	260547   Click image for larger version
ID:	260549   Click image for larger version
Old 07-04-2019, 05:38 PM   #9
type3
type3's Avatar
Trading feedback: (10)
Looks good. Any updates.
type3 is offline   Reply With Quote
Old 22-04-2019, 10:40 AM   #10
Rodeorayman
Haven't made much progress on this lately as family life and work is taking up all my time. The 2020 end date is looking unlikely at this rate but there is no rush tbh.
The crank has polished up nice and measures out nicely, so will be 8 dowelled when I get some more time, then off to balance.
As for heads I'm not having much luck as one of the 040s that looked ok revealed a hairline crack from the spark plug thread when cleaned up
Ill keep hunting through my stash must have some good ones in there somewhere lol
Ill try and get some pics up of the crank and heads soon
Rate This Thread:
