Water / Methonal cooling kits, any good? - VW Forum - VZi, Europe's largest VW, community and sales
Old 15-04-2019, 12:13 PM   #1
runningmonkey
I really must get out more
runningmonkey's Avatar
Default Water / Methonal cooling kits, any good?
What are folks thoughts on water/methanol injection / cooling kits
Iv got a charge cool set up on my turbo motor at the moment, but its not really cooling the charge as the radiator and pump are to small and Iv been advised to change the system to either an ice box setup or go water/methanol
CB Performance sell W/M kits but I don't know a great deal about how they work and what the results are like. Could anyone running W/M kit give some advice on whats best?
Cheers in advance John
My 1956 Oval Drag beetle Little Horus -
https://www.volkszone.com/VZi/showthread.php?t=1189194
runningmonkey is offline   Reply With Quote
Old 04-05-2019, 01:31 PM   #2
sako
sako's Avatar
Hi John.
I run a 23" x 6" x 2" chargecooler radiator up front of my bug in the spare wheel well, I have put a scoop to push air up into the well and removed the area behind the cooler which is just in front of the beam. I have enclosed the cooler with aluminium sheet ( removeable ).
I use a bosch pump from a Ford focus MK1 RS, this sits at the back on the frame rail. I also used a water additive called "water wetter", this aids heat transfer.
My inlet temps at most are 20c above ambient even when sitting at speed on the motorway or generally thrashing my bug, running 15psi boost.
I have thought of fitting a meth kit if I couldn't get the temps down, but managed it with fitting the bigger cooler up front. I also prop the bottom of my engine lid open to aid fresh/cool air into the engine bay.
Any questions please ask.
Jon.
sako is offline   Reply With Quote
Rate This Thread:
