Tarox Brake Kits - VW Forum - VZi, Europe's largest VW, community and sales
Old 21-09-2019, 04:47 PM   #1
Maltese '65
Maltese '65's Avatar
Default Tarox Brake Kits
Hey guys I am currently researching all the viable brake options for my '74 1303 Bug. I know that you can go with the DIY options of Porsche 944/924 stuff, but with the costs of the larger brakes and calipers going up( and it is used parts ) I started looking for alternatives. In this case it's these:
https://www.deikaferservice.com/shop...for-brake-drum
They look quite good, large calipers and vented discs, Much cheaper than other large calipers kits( csp and so on). Has anyone got any experience with this kit?
They need to be able to handle a little more power later on, and don't want to go through several brake systems along the way.
I know that these cars don't need that much braking force due to their lightweight , and would need the right front to rear bias to get the best of the brakes.
Maltese '65 is offline   Reply With Quote
Old 23-09-2019, 09:39 AM   #2
veltror
Not much cheaper then kerscher
https://www.kerscher-tuning.de/kaefe...msanlagen%20VA
veltror is offline   Reply With Quote
Old 23-09-2019, 06:19 PM   #3
Maltese '65
Thanks for the reply. That's why I'm asking, not really sure which way to go, when you consider that the the the car is quite light, even with interior and all the running gear/motor, the kercher looks quite good. And tbh I guess they would be enough as well. More research!
Old 23-09-2019, 09:55 PM   #4
type3
type3's Avatar
Trading feedback: (10)
I use Tarox 6 pot calipers on the front. I bought them years and years ago and only fitted them a couple of years ago.
They look swish and perform well. One downside is the brake pads are from an Alfa Arna of all things. The ones supplied didnít fit (different pin spacing) so had to figure it out.
type3 is offline   Reply With Quote
Old 23-09-2019, 10:07 PM   #5
type3
type3's Avatar
Old 23-09-2019, 11:43 PM   #6
vw60
vw60's Avatar
I have a set on my karmann Ghia, they are on a link pin front end with disc brake dropped spindles, so they are the same as the disc brake bearing area and caliper mount, the B27 calipers I have , have the same offset and mounting bolt spacing as the standard beetle caliper and bolted straight up to the dropped spindles. braking is very good and have a disc brake conversion on the rear, also run a 20.9mm master cylinder.
vw60 is offline   Reply With Quote
Old 24-09-2019, 10:48 AM   #7
Maltese '65
Thanks @vw60 they look quite good, this is mainly a street car but with added power you the braking performance. What type of braking system do you use on the rear?
Old 24-09-2019, 10:49 AM   #8
Maltese '65
@type 3 Thanks for your reply, yeah they look very good, and you can have them in different colours. What master cylinder and rear brakes do you run at the back?
Old 24-09-2019, 10:54 AM   #9
Maltese '65
bdw I have seen these kit as well
http://remmelemotorsport.com/bremsanlagen.html
Old 24-09-2019, 11:20 AM   #10
vw60
vw60's Avatar
I run a set of CB performance discs on the rear https://www.cbperformance.com/product-p/4359.htm with a 20.9mm MC. PS, you might be able to run the Tarox calipers on the standard disc brake spindle.
Tags
disc conversion, german look, tarox
Rate This Thread:
