Jobs For The Boys (& Girls) Positions Vacant and Jobs Wanted. If you have an opening, post your job ad here. If you have lost your job or on the look out for a new job, place your CV or wanted ad here. Also, if you need a freelancer, contractor or want to commission some work, this is the place. NO TOUTING, USE YELLOW PAGES. Forum available for sponsorship |
29-01-2012, 06:32 PM
#1
Plumbing in a washing machine into garage
Hi
Anyone in th Loughborough area who can plumb?
I have a washing machine that i want plumbing in, will need to run the cold from under the sink in the kitchen, around the edge of the garden and into the garage.
I need it to be able to work pretty much all year round so will need to be insulated.
Please PM me if your interested.
Dave
29-01-2012, 06:43 PM
#2
In that case, you will probably need it burying 750mm minimum, and a trace heater putting on too  Don't expect to get it done for a tenner
All this is assuming it's a dettacthed garage and no internal route is available. Also, bear in mind the waste too
29-01-2012, 07:22 PM
#3
A tenner?! I was thinking a fiver
Seriously though i dont know about burying the pipe as its all crazy paving along the route from under the kitchen sink/bib tap around the edge of the garden, approx 20m into the corner of the garage.
Would a well lagged pipe with trace heating not work?
Id be ok with not using it when below about 3 Centigrade as its a second washing machine.
Plus if pipe is above ground its easier to fix any splits/leaks.
Oh and yes it is a detached garage, trying to create a little laundry/utility room at one end of the garage.
Thanks for the input zippy - are you a plumber by any chance?
Dave
29-01-2012, 07:31 PM
#4
Builder,roofer,plumber etc etc
29-01-2012, 09:33 PM
#5
oops
Reason: duplicate post - doh!
02-02-2012, 08:46 PM
#6
nobody interested? - rather one of you guys than pot luck on a random out the paper/yellow pages.
03-02-2012, 02:33 AM
#7
All this is assuming it's a detached garage and no internal route is available. Also, bear in mind the waste too
WHS..
And by waste 67zippy means the dirty water that will be leaving the machine. Where's that going to go?
05-02-2012, 09:19 PM
#8
Hi Samba,
I was just going to run the waste out through the wall, theres a flower bed the other side of the wall which it could soak into.
Looks like im going to have trawl yellow pages and trusted plumber sites/reviews to find someone in local area as noone has pm'd me  thought i could help someone out and save myslef a few quid at the same time, obviously recession hasn't hit plumbers
Notts
05-02-2012, 09:23 PM
#9
You will need a propper drainage sytem, a soakaway is only suitable for rain water
Thread Tools |
Display Modes |
Linear Mode
Disclaimer: For recreational purposes only, some assembly required. Any resemblance
to real persons,
living or dead is purely intentional and the site admins are not responsible
for direct, indirect,
incidental or consequential ridicule resulting from any defect or failure to
perform. No animals
were harmed in the creation of this forum. Colours may fade over time. No other
warranty expressed or implied.
Supporting
