Help! Timing - grrr - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Old 17-03-2005, 12:08 PM   #11
alex1916v
alex1916v's Avatar
Trading feedback: (24)
the consumers choice
alex1916v is offline
Old 17-03-2005, 11:31 PM   #12
metric_thumbs
metric_thumbs's Avatar
As the aim of timing is to get the best out of your engine, and because there are lots of variables which determine where the best timing exists - I always go and test it on the road. Find a long hill with more or less fixed gradient. Try running up the hill at a fixed and known throttle openning, do it again and agin with slightly diferent distributor locations you will fin dthe best position. I have a local hill which I use and using this method got speed from 40mph to just over 50mph by moving away by aparently 5degrees from the 'ideal'.
Your own rolling road!!!
metric_thumbs is offline
Old 20-03-2005, 05:11 AM   #13
bathdub
Location: Latterly it was Radstock in Somerset, now I live in Napier New Zealand, where there aren't many VWs
The mystery explained:
TDC is not marked, the other two notches are 5 and 7∞C BTDC. Vacuum advance only distributor. The root of the problem was that the wire connecting the base plate to the body of the dizzy was broken. With a replacement distributor and the engine timed to 7∞ BTDC the engine runs sweet!
bathdub is offline
[IMG] code is Off
