oil change problem - VW Forum - VZi, Europe's largest VW, community and sales
Old 24-03-2005, 11:21 AM   #1
oldschool71
oldschool71's Avatar
Default oil change problem
hi there just changed my oil this morning on my 1300, 71 bug and when i was doing up the six nuts that secure the oil strainer plate, one of the nuts was turning without tightening. great i thought, but it gets worse!!! the thread on the nut is fine and the thread on the stud is good but the thread in the botom of the engine case has been stripped!!!!!! ohhh fuk
so what do you recon is the best was to fix the thread????
i thought i could heli-coil it but im not sure if they will seal the oil???
or could i go to an M8 thread???
any help or advice would be greatly appriciated
cheers, andy
oldschool71 is offline
Old 24-03-2005, 11:35 AM   #2
Moby5153
Tech Guru/Mr VZi '06
Moby5153's Avatar
VZi Member Sponsor
Studs are available that enable you to drill and tap the case to 8mm yet still retain the 6mm exposed stud. Probably most suppliers stock them, but if you have a problem finding some mail me.
I think the part number is N 014 478 1 (M8/M6x21)
Moby5153 is offline
Old 24-03-2005, 09:12 PM   #3
oldschool71
lovely mody cheers il have to check that one out! it must happen alot if they make a stud for it!!
Old 24-03-2005, 09:21 PM   #4
Moby5153
Moby5153's Avatar
VZi Member Sponsor
When you consider there's been well over 120,000,000 of those standard studs made and regularly used over the years for every oilchange, 'common' becomes relative with the oversize ones.
Nearly all studs are available in an oversize form.
Moby5153 is offline
[IMG] code is Off
