1303 starter motor - VW Forum - VZi, Europe's largest VW, community and sales
Old 29-08-2005, 07:58 PM   #1
BURBLES
Default 1303 starter motor
how do u get it off,have taken live,earth,and 15mm nut off but wheres the other nut,all i can find is a weird lookin thingy (in the most arse of an awkward place )in the shape of a half moon,is this a threaded rod shootin the opposite direction and if so how do u get to the nut,
HELP,me only got one knuckle left to skin
BURBLES is offline
Old 29-08-2005, 08:12 PM   #2
Moby5153
Tech Guru/Mr VZi '06
Moby5153's Avatar
VZi Member Sponsor
The other end of the half moon bolt is in the engine bay. It is also the top right engine securing bolt ie. it does both. It has a head that shape so the bolt can't go round with the nut when you try to undo it.(17mm ring spanner)
Moby5153 is offline
Old 29-08-2005, 08:30 PM   #3
BURBLES
thought it was sumthing like that,how much do i need to strip out the bay to get to that bad boy then
BURBLES is offline
Old 29-08-2005, 08:42 PM   #4
Moby5153
Moby5153's Avatar
VZi Member Sponsor
Originally Posted by BURBLES
......how much do i need to strip out ...
Just the airfilter assy. if you have a stock one, then put your hand round the back of the fan housing and find it. A bright light and mirror might help you first time round. Have a grope in the fan at the same time to check for anything stuck in the blades, worth doing while you're there.
Moby5153 is offline
Old 29-08-2005, 09:13 PM   #5
BURBLES
cheers dude
BURBLES is offline
Old 30-08-2005, 07:03 PM   #6
BURBLES
aint that tough after all,all i need now is the right bloody starta mota to fill the hole as the guy at GSF gave me a different one,
BURBLES is offline
Old 30-08-2005, 08:25 PM   #7
Moby5153
Moby5153's Avatar
VZi Member Sponsor
A new starter (when you get the right one) comes with a new bush attached. Fit the new bush, don't skimp on it.
Moby5153 is offline
[IMG] code is Off
