Useful Tools - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-07-2007, 03:31 PM   #1
yellow_spider
yellow_spider's Avatar
Default Useful Tools
Apart from the usual screwdrivers / plieres / socket sets / timing light / axle stands etc , heres a few tools i have found to be very useful for working on my dub (and others too)
Pipette
http://img.photobucket.com/albums/v2...ls/pipette.jpg
Very useful tool for removal of brake fluid and other fluids.
DeadBlow Hammer
http://img.photobucket.com/albums/v2...low_hammer.jpg
Great for persuading brake drums off that are stuck without much risk of damage to the drum.
Griping Pliers
http://img.photobucket.com/albums/v2...rip_pliers.jpg
These are great for rounded off brake pipe unions / nipples / bolts as they grip tighter the more you turn. Nearly always removes stubborn fixings allowing replacement.
Brake Shoe Hold Down Tool
http://img.photobucket.com/albums/v2...down_fixer.jpg
Does not look much but good for holding the shoe hold down clips and twisting them on easily.
Andy. :)
yellowspider (nothing to see at the moment)
Dubtime
yellow_spider is offline
Old 07-07-2007, 03:32 PM   #2
yellow_spider
Pipe Clamps
http://img.photobucket.com/albums/v2...ipe_clamp1.jpg
http://img.photobucket.com/albums/v2...ipe_clamp2.jpg
Easily and safely shut off rubber pipes (fuel / brake hose etc) without risk of damage while working.
S-Shaped Spanners
http://img.photobucket.com/albums/v2...ed_spanner.jpg
Extremely useful for tight spots such as around the carb nuts
Ratchet Spanners
http://img.photobucket.com/albums/v2...et_spanner.jpg
Easy to use and a great time saver. Everyone should have a set of these.
Magnetic Telescopic Pickup
http://img.photobucket.com/albums/v2...ic_pickup1.jpg
http://img.photobucket.com/albums/v2...ic_pickup2.jpg
Excellent for retrieving small metal parts you drop (nuts / washers etc) where you shouldnt.
Andy. :)
Dubtime
Old 07-07-2007, 03:32 PM   #3
yellow_spider
Large Grips
http://img.photobucket.com/albums/v2...arge_grips.jpg
Useful for a variety of purposes.
Large BallJoint Fork
http://img.photobucket.com/albums/v2...large_fork.jpg
A bit brutal (the joint will probably be damaged) but an easy way to seperate balljoints that need replacement anyway.
Flexible Claw Pickup
http://img.photobucket.com/albums/v2...aw_pickup1.jpg
http://img.photobucket.com/albums/v2...aw_pickup2.jpg
Great for when you drop something and cant get your hand in to reach it. The stem is very flexible allowing you to reach into small spaces with ease.
Large Prybar
http://img.photobucket.com/albums/v2...rge_prybar.jpg
Useful for several jobs when a bit of extra leverage is needed.
Ball Joint Removers
http://img.photobucket.com/albums/v2...oint_tools.jpg
Easy to use tools to remove balljoints.
Andy. :)
Dubtime
Old 07-07-2007, 05:36 PM   #4
spannermanager
spannermanager's Avatar
Default tools
mate, i cant see any blood staines on those tools, or grease come to that !! gofer it !
spannermanager is offline
Old 07-07-2007, 09:25 PM   #5
yellow_spider
Theres plenty of grease and dirt on them
I just thought id post up some things i find useful incase anyone is thinking what would be a useful addition to their toolboxes
Andy. :)
Dubtime
Old 07-07-2007, 09:50 PM   #6
iain ambrose
iain ambrose's Avatar
You forgot...
http://www.aspli.com/prdimgs/060004.jpg
For when all else fails
iain ambrose is offline
Old 07-07-2007, 11:08 PM   #7
yellow_spider
Thats an essential item though , so not in my list.
I was listing useful tools that might not be part of peeps toolboxes but they might consider getting
Andy. :)
Dubtime
Old 07-07-2007, 11:25 PM   #8
rubbachicken
rubbachicken's Avatar
Trading feedback: (3)
Originally Posted by iain ambrose
You forgot...
very very important in making type 4 engines run
http://img.photobucket.com/albums/v1...t/type2648.jpg
rubbachicken is offline
Old 08-07-2007, 12:49 AM   #9
Clarkson46
I really must get out more
Clarkson46's Avatar
As they say "Don't force it, use a bigger hammer"
Clarkson46 is offline
Old 08-07-2007, 01:51 AM   #10
rubbachicken
i thought it was
when you have a hammer in you hand
every problem looks like a nail
[IMG] code is Off
