My '59 Beetle Xmas pressie! - Page 54 - VW Forum - VZi, Europe's largest VW, community and sales
Old 16-01-2011, 11:17 AM   #531
psimitar
psimitar's Avatar
Cheers J
I like tidy wiring esp as part of me job I come across switchboards wired by an ameba and thats being rude to ameba's.
So doing lots of little jobs all week and nothing really noticeable but finally got the washer bottle frame made and welded in
Just need the pipe to the washer jet and done, as parts place were out of it.
Brakes have gone thro half litre pumped out and not up the top yet but some resistance at the bottom so hopefully getting there.
Door aperture will be jacked wider at the top this week and engine bearings are on there way
Um, what else. Oh yea the driver window was very hard to wind up so took apart and the slide and window holder are rusty as all hell so fitted a little roller bearing roller and will make up a new window holder and slide as the roller is 5mm bigger.
Also, shall make new steel part of the orig door switches and what else, oh sterring column fitted up and ind switch done just steer wheel to rub down epoxy putty and spray. Book engineer this week and maybe sandblast the front wheels
6 weeks to get it MOT'd. Oh yes I'm not joking so I'll be fecking knackered by then. Plus I've found a cheap EJ22 engine I'll buy before we head to europe in march
madness is in the eye of the beholder
My '59 Beetle Resto Part I
My '59 Beetle Resto Part II
56 Oval Resto
psimitar is offline   Reply With Quote
Old 19-01-2011, 11:53 AM   #532
psimitar
psimitar's Avatar
Default door gap enlarging
So here's one way to enlarge a door aperture that has shrunk due to a hanging door or whatever made it 5mm too small
left it like that for a day to help the metal get a new memory and shall see what happens tonite
After consultation on tech forum I shall give the brake bleeding one more go before buying a vacuum bleeder and pray that it works
Slow going cos of late nights at work and with cold now so not a great start to the new year after a virus for the first week of it
56 Oval Resto
Old 19-01-2011, 12:21 PM   #533
TwoToneAlex
TwoToneAlex's Avatar
Trading feedback: (11)
Good work
I can't wait to see this finished!
I know what you mean about cold nights, i've been working in the garage in the evenings until late, I'm end up shaking so much from the cold I can't hold a spanner
Antique Extraordinaire.
TwoToneAlex is offline   Reply With Quote
Old 19-01-2011, 02:14 PM   #534
iain ambrose
iain ambrose's Avatar
When I did my last project the door aperture was also wrong.
The most important thing is that the width at the bottom is correct.
On mine I had to correct the heater channels position to get the right width.
When I then hug the door it was completely out of shape.
I did something similar except I used the brace from the bottom left corner diagonally to the middle of the windscreen piller. This restored the shape to the aperture and then door subsequently fitted perfectly.
I would double check the gap at the bottom and if it's incorrect you will need to rectify it to get the doors right.
The correct gap is 950mm - 951mm.
Best of luck.
Old 20-01-2011, 12:14 PM   #535
psimitar
psimitar's Avatar
Best of luck.
Cheers Iain I know the bottom is about 5mm out due to me cloating the impact driver so hard so shall see about that. I've tried the door and it fits lovely around the top and the swage lines up. Just the bottom the either cut and weld or see if a slide hammer will pull it back.
Originally Posted by TwoToneAlex View Post
Good work
Ah, not cold nights here but I have a cold. It's so muggy here at the mo that we sleep above the sheets until about 3am when the temp finally drops enough for the sheet. Takes ages to fall asleep too.
Buying the EJ22 motor this weekend too plus some more parts tomoro
56 Oval Resto
Old 20-01-2011, 01:20 PM   #536
TwoToneAlex
I was going to say... it'z Oz
Old 21-01-2011, 09:56 AM   #537
psimitar
psimitar's Avatar
I hate being unwell. Viral thing for 1st week of new year and then wife turned that into a coldy type thing that I caught back. Oh well, if brain can handle it I'll order me vac bleeder tonite.
56 Oval Resto
Old 08-02-2011, 01:08 PM   #538
psimitar
psimitar's Avatar
Hello everyone.
Sorry for lack of updates. I've been flat out trying to get her ready for MOT and what with work and marital issues I'm just plain knackered!!!!
Anyhow, here she is escaping the garage for the first time in 2 years and for the first time in waaaaayyyyyyy longer than that on 4 wheels.
Bottom drivers hinge area has been ripped open to remove snapped off door bolts so that to de-rust and clean up, then MC rear circuit was knackered on new MC so another ordered plus gotta source a Volvo 240 res to go with it. Both R33 seats are finally bolted in and I just remembered I've not photo'd the engineers plate I got on Friday to say my mods pass the test. Gotta fab a rear seat support but he knows I'll do that.
Engine case will be together once I know how to stop the oil pick up moving and cylinder heads are being reconned as we speak.
Getting so close I can smell the sulphur
56 Oval Resto
Old 12-02-2011, 05:43 PM   #539
roebucksplit
roebucksplit's Avatar
good work well done
roebucksplit is offline   Reply With Quote
Old 01-03-2011, 02:04 PM   #540
psimitar
psimitar's Avatar
So apologies for lack of updates. I've been flat out with work, the Beetle and marital issues.
Anyhow, here's some pics to show what I've been up to.
Engine going together
Nice reconned heads with new guides and valves
Seats are now bolted in
Rear seat rail supports to pass ADR regs
Volvo 240 res on new MC that finally bled
Hookeys door repair panel and hole in door post
and an cheap EJ22 to throw in the back when I return from my travels
So I should have the door post welded in my end of week along with the engine ready to install and hopefully start
56 Oval Resto
