Help! Sheared front gearbox carrier bolt. - VW Forum - VZi, Europe's largest VW, community and sales
Go Back   VW Forum - VZi, Europe's largest VW, community and sales > Tech Forums > Engineering Tech
Engineering Tech A Q & A Forum devoted to Engineering Issues that don't necessarily fall into Aircooled or Watercooled Tech. Got a problem? Or an engineering question? Even a buildings or property engineering question? Then ask in here. Please, no 'For Sale' or 'Want To Buy' ads, plugs for your 'business', links to 'for sale' ads or Ebay links to your (or your mate's) auction (use the VZi 'Classifieds' section) - this also includes thinly veiled 'What's My Car Worth?' threads and "Who Can Sell Me A . . ." posts.
Old 08-05-2020, 04:08 PM   #1
bugs3823
Default Help! Sheared front gearbox carrier bolt.
Any help would greatly be appreciated. Whilst installing gearbox into refurbíd chassis, Iíve managed to shear the bolt that is welded into the chassis tube , that the front gearbox carrier mount attaches to.
Any advice on how I could rectify the problem. Can it be drilled out and replaced? Stuck now as canít continue my chassis build until I can secure the gearbox mount fully.
Thanks
bugs3823 is offline   Reply With Quote
Old 10-05-2020, 01:00 AM   #2
yoda
yoda's Avatar
Thanks
from what i can see. Remove the g/box mount for easier access. Drill out the broken bolt too just under the thread size of the bolt. Then using an easy-out or similar torqbit try to remove
the broken stud. make sure you use plenty of lube wd40 etc.
Iftht fails drill to close to the size and retap the tread
yoda is offline   Reply With Quote
Old 10-05-2020, 05:25 PM   #3
bugs3823
Much appreciated!
Old 11-05-2020, 10:20 AM   #4
flat4fanatic
flat4fanatic's Avatar
Trading feedback: (8)
Cut another bolt down, crank up the heat and weld on where it's snapped as it'll be below where you need the thread
flat4fanatic is offline   Reply With Quote
Old 11-05-2020, 10:21 AM   #5
flat4fanatic
ps eurethane mounts will last less than 12 months
Old 13-05-2020, 10:45 AM   #6
Manxdavid
Manxdavid's Avatar
Trading feedback: (4)
The bolt is welded into the chassis, an Easy out won't work as there is no stud there to remove, it's not just threaded in.
David Jones, Anglesey, North Wales, UK.
"Wise men talk because they have something to say, fools because they have to say something." (Plato)
Manxdavid is offline   Reply With Quote
Old 13-05-2020, 10:46 AM   #7
Manxdavid
Manxdavid's Avatar
This ^^^
Old 17-05-2020, 09:44 AM   #8
andy198712
andy198712's Avatar
Also worth getting a torque wrench too, sometimes these old studs just sheer but at least if you use a torque wrench you know its CORRECT in your mind and less chance of it happening again i love mine.
andy198712 is offline   Reply With Quote
Old 17-05-2020, 10:21 AM   #9
Manxdavid
Manxdavid's Avatar
Sorry, disagree, unless your torque wrench has been checked and calibrated recently, most torque wrenches are way out, even quality ones used in industry. I never trust them.
The only three values you need on a Bug are nipped, just tight enough and 'kin tight
Old 17-05-2020, 06:49 PM   #10
andy198712
andy198712's Avatar
hmmmm fair enough.
i have a halfords one, comes with a calibration certificate, i also check my regularly on calibrated machines at work and its always been spot on.....
i was pleasantly surprised.
i think what harms them is when people use them as breaker bars.
also quality ones used in industry should be regularly calibrated anyways.... and checked before each use. thats our policy at work....
