id like to learn to weld. (devon, cornwall) - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Old 11-10-2010, 10:58 AM   #21
356uk
I really must get out more
Trading feedback: (4)
YEAH SHAME YOUR NOT sOUTHAMPTON WAY AS i CAN SHOW YOU.. i HAVE LOTS TO DO TO A FEW PORSCHES WHY AM i IN CAPS HMMMM
356uk is offline   Reply With Quote
Old 12-10-2010, 08:38 PM   #22
devonduboy
devonduboy's Avatar
Originally Posted by fruitcakes23 View Post
Hi there, did you receive my pm?
i did, looking forward to when you get your gear sorted and we can sort something out
oval panels wanted
devonduboy is offline   Reply With Quote
Old 12-10-2010, 08:41 PM   #23
devonduboy
devonduboy's Avatar
Originally Posted by redoxide View Post
Hi, back to your welding question, I see your welder is a 130, my guess is that it will be a hobby machine? If so is it fair to say that the current and wire speed adjustments are limited with rocker switches? Next my guess is you could be using CO2 as a shielding gas?
If thats the case your welding will be greatly improved with better quality gear with a greater range of current and wire speed control.
Ditch the CO2, its not the best for shielding, your better to commit to an account with a gas supplier and go for Argoshield ( BOC ) or Cougar ( air products) which are a CO2/Argon mix.
With the corect settings and the proper gas and some practice, your welding will be more consistent.
I would also agree with what wa said in a earlier post re the wire size, 0.6 wire is all you will need for panel work, 0.8 is way to thick,
Keep the gas cup close to the job to ensure that the gas does its job of sheilding the weld area, if the wire is pushing you off the job, slow the wire speed down.
Ensure that both sides of the material are cleaned and the job is propely earthed.
what m going to say next might be a bit contravercial, where mig has its place for attaching metal to metal, where it comes to bodywork O/A is much better. People seem to think that oxy acetalene causes distortion which is had to fix. Its not true for the best prt. Any welding process will cause heat in the weld area which will shrink the material along the heat affected zone. This is where it gets interesting.
If you butt weld panels together with MIG you will have to grind the weld flush, a couple of things are happenig here,
1/ your adding material in the form of weld wire to create heat and weld area.
2/ you have to grind the weld area and in doing so create more heat
The hardness of mig weld doesnt allow you to sort the shrunk area by stretching with a hammer and dolly, hence why most mig welded repairs are plastered with body filler.
O/A on the other hand doesnt require the additio of filler wire if done properly, the panels can easily be but welded edge to edge with no filler wire and therefore no aditional material is aded to the weld area.
Once the weld is complete the heat affected area can be lightly hamered and dollied to re strretch the weld area bringing it back to normal, in the process the weld bead will also be plannished out requiring no griding, so your left with a panel that needs very little final prep.
dont use overlap joints or joggled edges thats bad practice for a number of reasons . get out of the habit as soon as you can.
hope that helps, could go on but need to dash off to work ... cheers for now ..
cheers for the info mate, much appreciated.
have taken it on board
oval panels wanted
Old 16-11-2010, 11:12 PM   #24
devonbug
Trading feedback: (22)
pm your details. i have a good mig and the correct gas. plenty of metal to pratice on.
devonbug is offline   Reply With Quote
Old 06-12-2010, 09:51 PM   #25
futbus
Contact exeter college as they run night school courses in welding in all areas mig, tig and arc.
www.futbus.com www.facebook.com/#!/Futbus
Brake conversion kits for T2, T3 and more
Any machining work give us a call on 07866 581136
Located in South Devon
futbus is offline   Reply With Quote
Old 11-12-2010, 10:04 AM   #26
rob mcreedie
rob mcreedie's Avatar
that's what I did
Exeter Aircooled
rob mcreedie is offline   Reply With Quote
