Type 4 conversion - Page 3 - VW Forum - VZi, Europe's largest VW, community and sales
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 09-10-2009, 10:07 PM   #21
mark sirett
mark sirett's Avatar
Trading feedback: (3)
Originally Posted by splitty64 View Post
Take a look at my thread listed below, Full 2276 in a splitty
my engine bay looks like that but dirty
I am really pleased with DTM but on the way back fromEBI were were cruising at speed and I did wonder whether beyond 85 mph the air was going past the vents quicker than the fan could pull it in. What do you think?
mark sirett is offline   Reply With Quote
Old 09-10-2009, 11:07 PM   #22
paul_f
paul_f's Avatar
Trading feedback: (4)
Originally Posted by aircoolsteve View Post
the only other issue not mentioned on this thread is that the gearbox imput shaft on a bug box is shorter than that of the type4 bus box. this means that the end of the shaft is not supported.
you can overcome this by having the centre of the T4 flywheel opened up to take the standard needle race bearing that the type 4 uses in the end of the crank. its not a good idea to run an engine without doing this or you run the risk of clutch/imput shaft failure.
hope your conversion turns out well.
Hey Steve, your definately right there - don't use the conversion bushes either - they are too thin and i wore one out in 2k mile holiday around Europe - the input shaft seal of my old gearbox was pissing out everywhere
paul_f is offline   Reply With Quote
Old 14-10-2009, 02:38 PM   #23
69vanagonman
Interesting. I'm using this one: http://www.airtechvw.com/store/index...d&productId=19
69vanagonman is offline   Reply With Quote
Old 14-10-2009, 04:52 PM   #24
liam 914
If anyone is interested in a spanking 2l type 4 engine from a 914, see my post https://www.volkszone.com/VZi/showthr...=594546&page=2
liam 914 is offline   Reply With Quote
Old 14-10-2009, 07:02 PM   #25
Jinx
Trading feedback: (11)
so wheres the details?
Jinx is offline   Reply With Quote
Old 23-10-2009, 10:01 AM   #26
paul_f
paul_f's Avatar
Originally Posted by 69vanagonman View Post
That is the proper bearing, but a standard flywheel (210 or 215) needs machining to fit one of these.
The other type is a bronze bushing that pushes into the flywheel, but they do not last
Old 17-11-2009, 11:23 AM   #27
splitty64
splitty64's Avatar
I think the issue is the CFM the fan requires for cooling, along with the cfm the carbs are sucking, may well get close to exceeding the cfm that can be drawn through the vents. Saying that, I have had no problems yet. Next step will be to create some out of sight ducting from underneath into the engine bay for some extra air. Must do this before Mr turbo comes knocking on my door
GOAP racing
Push it to the limit!
Check my split! :incheek:
splitty64 is offline   Reply With Quote
Old 17-11-2009, 04:57 PM   #28
Jinx
i think thes is not the problem - i asked a f1 engineer to look in to it, when i told him the sizes of the vents on a late splitty he quickly replied that it wouldnt cause a problem
there may be issues with, as the air rushes past the vents at speed, the air inside the engine bay is drawn out of, in the same way as a traditional spray gun works?
id like to try this theory by fitting a smoke 'bomb' inside the engine bay and driving at speed, then have someone film the smoke escaping from the engine bay
the theory says thet the smoke should come out of the side vents
but my van is along way from being on the road!
Old 18-11-2009, 09:36 AM   #29
splitty64
splitty64's Avatar
Cool, I have seen similar on another forum, so am thinking long term about ensuring this doesnt happen. But !!! not sure my ears would hold out for long term high speed cruising!! may strip the van and dynomat it, see if that makes a significant difference.
GOAP racing
Old 18-11-2009, 07:12 PM   #30
Jinx
ive see a mate's mod to his bay
he has fitted come flexi pipe from the side of the gearbox to the engien bay, thru the gearbox tin, opposite to the doghouse exit, at speed it appears to blow air to the fan and aid cooling
im thinking i may utilise the existing heating pipeing and put a scoop at the front of the van, thru the centre pipe and up to the engine bay
im not running heat exchangers
and im using a propex!
Rate This Thread:
