About time i showed you my '70 1300. - Page 2 - VW Forum - VZi, Europe's largest VW, community and sales
Closed Thread Post New Thread
Old 10-10-2007, 07:01 PM   #11
Zebedee
Zebedee's Avatar
Trading feedback: (6)
Finally got around to doing some more work on my bug.
Replacement second hand bonnet, wirebrushed and with a coat of filler, then sanded down and primed.
ID:	267781   Click image for larger version
1970 1300 Beetle resto here
1970 1300 Beetle part 2
Me on Instagram Zebedee_vw
Zebedee is offline
Old 14-11-2007, 09:19 PM   #12
benjyhas
benjyhas's Avatar
I really like steel sunroof bugs!
Will keep an eye on this one
Ben
benjyhas is offline
Old 14-11-2007, 09:52 PM   #13
Spacematt
Spacematt's Avatar
Nice work fella The weldngs look mint
Let's Take The Engine Out Again
This Should Be The Last Time
Spacematt is offline
Old 14-11-2007, 09:54 PM   #14
Johnser
good effort cutting out all those little holes and making the right shapes to fit! like your engine side trays too, feels like something I might do. keep up the good work!
Johnser is offline
Old 11-02-2008, 09:32 PM   #15
Zebedee
Zebedee's Avatar
After not being able to do anything on my bug for weeks due to the weather i finally decided to build a carport so i can work outside even if its raining. Its high enough to get my bay under too.
Next job, heater channels and door pillar bottoms.
Zebedee is offline
Old 11-02-2008, 09:42 PM   #16
event horizon
event horizon's Avatar
Nice bug you got there, Keep the updates coming.
event horizon is offline
Old 12-02-2008, 12:03 PM   #17
Zebedee
Zebedee's Avatar
My missus is sick of the sight of it as its been sitting outside the kitchen window for the past 3 years now.
Gotta get a crack on with it now and get some use out of it.
Zebedee is offline
Old 23-02-2008, 07:24 PM   #18
Zebedee
Zebedee's Avatar
A couple of pics showing the rot i've gotta sort out.
Its already had the channels bodged before so i'm cleaning up other peoples dodgy repair work which is a bugger.
ID:	216217   Click image for larger version
ID:	216225   Click image for larger version
ID:	216233   Click image for larger version
Zebedee is offline
Old 23-02-2008, 07:31 PM   #19
Zebedee
Zebedee's Avatar
Needs a new door pillar bottom to go with the channel.
The inner front arch replacing again. I think it was chewed off when it was replaced last time.
Chassis needs napoleon hat section and front of floorpan repairing too.
ID:	216193   Click image for larger version
ID:	216201   Click image for larger version
Zebedee is offline
Old 25-02-2008, 11:53 AM   #20
Zebedee
Zebedee's Avatar
I have the horrible feeling that if i remove the two tacked on plates off the inner arch i'll find a huge rusty hole underneath.
It seems to have had a rear suspension panel welded in and i'd put money on it that the rot wasn't cut out beforehand.
Looks OK and solid from under the wing though.
Zebedee is offline
Tags
1300, beetle, rally, resto
