Breathing life in 1600tp - VW Forum - VZi, Europe's largest VW, community and sales
Old 07-03-2017, 06:25 PM   #1
kiwitodd
Question Breathing life in 1600tp
Hi
Looking to give a bit more life into the stocker I have
Thinking
Twin dell36 with vintage speed airfilters with breather pipes , going to breather tower
V.s exhaust with heaters
Serpentine kit?
Thin sump
Cb pump to make external oil cooler?
kiwitodd is offline   Reply With Quote
Old 07-03-2017, 07:13 PM   #2
kiwitodd
+ vs linkage
ID:	188249   Click image for larger version
ID:	188257   Click image for larger version
Old 07-03-2017, 07:14 PM   #3
kiwitodd
Airfilter
Oil filler/breather
Hi flow breather system
Old 07-03-2017, 10:06 PM   #4
standard60
That's all bolt on stuff I'm afraid...
Sort out the heads with a good valve job polish and port
Balance the crank and flywheel etc
Then worry about ya bolt on goodies
Perfect choice on the carbs
Deep sump etc with a cooler
standard60 is offline   Reply With Quote
Old 08-03-2017, 06:30 AM   #5
kiwitodd
Port polish heads, match to manifolds
Lighten flywheel, 8 dowel?
3.88 gear box?
Old 08-03-2017, 08:53 AM   #6
kiwitodd
Plus
123 or petronix ignition
Old 08-03-2017, 10:40 AM   #7
clarkson
clarkson's Avatar
Originally Posted by kiwitodd View Post
Hi
Thinking
Serpentine kit?
Thin sump
Twin 36s and the airfilters, although those air filters will do nothing that a standard one won't. Forget breather towers, they are bolt on junk that will most likely make your engine worse, the stock one is best. Serpentine kit, looks great but unless you are going to be making super high revs it is pointless. Oil cooler on a stocker will probably make it worse. Get your self a stock SVDA and fit an Accuspark ignition module. Those fancy dissys won't give you anything that a stock unit doesn't already do. Don't bother with deep sumps they are pointless.
Personally I'd fit the carbs, exhaust and electronic ignition and then make sure the rest of the ancillaries are as good as they can be. i.e Make sure all the correct tinware is in place with flaps and a thermostat. Don't bother with repro tinware, s/h OE stuff is far superior. Once all that is done, see how it is. The carbs will give you a fair boost in power on their own.
After that start looking at heads and cams.
It's all about the FWEEM!!
clarkson is online now   Reply With Quote
Old 08-03-2017, 07:10 PM   #8
kiwitodd
Thinking of the cb panchito 044 heads (standard bore) and their matched manifolds ,
Exhaust
Ignition
Twin dells
Should be a good start
Old 09-03-2017, 08:36 AM   #9
clarkson
clarkson's Avatar
Exhaust
Ignition
Twin dells
If you are going for heads like that then you'd be better off with a cam and a set of rockers too.
Personally I'd have work done to my existing heads rather than something that was made of purest Chineseum.
Old 09-03-2017, 09:48 AM   #10
kiwitodd
Ignition
Exhaust
Carbs to start as you suggested
THEN ........
Rate This Thread:
