'72 Crossover Van - Page 54 - VW Forum - VZi, Europe's largest VW, community and sales
Old 20-09-2019, 11:49 AM   #531
gninnam
gninnam's Avatar
Originally Posted by Zebedee View Post
Just thought, is the arm on the clutch pedal fitted the right way round? Can't quite make it out in the piccy up there /\.
I believe so - will try and get a pic of it tonight.
'72 Dormobile.
Please visit my web site to see how the van is doing - MY VAN
Loads of work to do - will I get to use it this year :(
gninnam is offline   Reply With Quote
Old 21-09-2019, 10:02 AM   #532
gninnam
gninnam's Avatar
Best picture I can get
Looks correct to me!
'72 Dormobile.
Old 21-09-2019, 10:25 AM   #533
You're right it does.
Maybe it is just a wrongly labelled cable and its shorter than it should be.
This piccy was on thelatebay forum:
Name:	Clutch lever flipped.jpg
Old 21-09-2019, 11:34 PM   #534
gninnam
gninnam's Avatar
That is what I am thinking
Will take it out (again) tomorrow and measure.
'72 Dormobile.
Old 22-09-2019, 06:57 PM   #535
gninnam
gninnam's Avatar
So - took the cable out and measured it - give or take 5mm its as per the label, it measured about 3210 so can't blame them.
It looks like I need the pre '71 cable then so will give them a ring tomorrow and hope we can do a swap.
Also, rain stopped play so no real work made today.
'72 Dormobile.
Old 27-09-2019, 08:54 PM   #536
gninnam
gninnam's Avatar
Hurrah - got the longer clutch cable (for the 71 year only) which is perfick
Will take it out (again) now I know it's good and grease it and fit the rubber boots to go over the ends of the to stop rubbish getting into the tube....
Weather is crap this week so this is all I could do.
'72 Dormobile.
Old 30-09-2019, 05:35 PM   #537
Still a bit weird a 71 cable is the right length but nice its now sorted.
Old 19-10-2019, 03:47 PM   #538
gninnam
gninnam's Avatar
It is and thanks!
'72 Dormobile.
Old 19-10-2019, 03:49 PM   #539
gninnam
gninnam's Avatar
Carburetor time so let’s give a clean and replace some gaskets and stuff.
Here we are:
This gasket has seen better days:
Old one on the left but the rubber is thicker:
Nice and clean:
New one on the right……. Cleaned out the old one and put it back:
All done:
Just need an air cleaner to go on top.
Connected to the manifold now so almost ready to put the engine in……...
'72 Dormobile.
Old 19-10-2019, 05:46 PM   #540
Looks nice and clean now.
Give the brass fuel inlet a quick pull with some pliers to make sure its still secure. And safety wire it anyway once its back on just incase.
