1 - 10 of 10 Posts
i fitted the bestek dizzy to my mates mk1 rs2000 last weekend which is similar to the 123 and that is real good, made hell of a differance, there is a switch on the bottom to change the different advance curves to
Have one of these sitting on the side ready to give it a try.. a couple of things to note that I've found out while investigating are:
  • coil needs to have a minimum primary resistance of 1 ohm (link)
  • apparently you won't get any significant (extra) improvements by teaming one up with something like a 6AL (link)
[SOURCE: 123 Ignition forum]
Doh! Guess I'll have to find another use for the MSD 6AL and Blaster (0.7 ohm) coil I've assembled to go with it!
PS. Anyone recommend a good higher output coil that has a higher primary resitance?
PPS. Random fact found during my investigations - the MSD is not compatible 'out of the box' with the Optronic electronic ignition system as the signal curve is inverted. Doh!
1 - 10 of 10 Posts
