1 - 16 of 16 Posts
Hello
Having trouble loading your pic? Are these pumps the type with a universal 'push-on pipe' inlet and outlet, or the type that fit in the bottom of a bottle?
Discussion Starter · #8 · (Edited)
yeah no problem, it is a pretty easy job. You connect the pump via it's 2 terminals to a switch on/under your dash and then the pump has IN and OUT push on connectors on it which allow you to push on the thin rubber tubing that goes from your washer bottle to the washer jets on your bonnet. The pump can then basically fit anywhere between the washer bottle and the washer jets. It has a universal fitting on it so a couple of self tapping screws will fix it in a suitable location
So tube from washer bottle > IN > pump > OUT > tube goes to washer jets, job sorted! :D
OK, I doubt my explanation wil make it into the Tech archives, but hope that makes sense?
1 - 16 of 16 Posts
