can they be put on a 63 beetle - possibility of getting a 1600 1303s engine and gearbox for my bug - but i need to know if it is possible to do it (convert to IRS), and is it possible to use the front discs on a 63 beetle kingpin/linkpin suspension setup?
would the 1303s box give me better cruising on the motorway, as at present i have a early 70's box mated to a 1600 engine... dont know the gearbox code, but is it possible....
if anyone has done this please let me know
much appreciated for the info
Jack
well 1303s is the best gearbox you could wish for with its really high gearing, it`ll give you ideal cruising speed.
the conversion of bits involves, welding 2 A-arm brackets to your existing chassis so that you can fit the rear IRS A-arms/spring plates/torsion bars, you`ll obviously need the driveshafts/gearbox, the only thing im not sure about is the nose cone mounting, i know 1303s are different to all other, i think you should be able to just use the gearbox nose cone from your old box *i think*
front brakes, you`ll need disc brake spindles for king/link pin alternative would be balljoint beam conversion, for which you can easily get spindles, the calipers/discs/backing plates you can use. i think thats it :tick:
:hangloose
Bernice said:
Is there any diff between 1302 and 1303 irs and gearboxs?
3 differences I have come across..
1) generally speaking 1302 gearboxes have the early style front nose cone mount found in most 60s cars, where as the 1303 has a 3 bolt type which is totally differen, but adaptors are available i think, sure i seen them.
2) some gearboxes have 2 side plates, some just have it on one side
3)the gear ratios are mildley different:
1302
1)3.80:1
2)2.06:1
3)1.26:1
4)0.89:1
R)3.61:1
1303
1)3.78:1
2)2.06:1
3)1.26:1
4)0.93:1
R)3.79:1
Final Drive
1302
1300 4.375:1
1600(s) 4.125:1
1303
1300 4.375:1
1600(s)3.875:1
now while that all might look like just numbers what it means is that for example, as i have noticed, with(205/65 R15 Tyres) a 1300 1303 box 70mph was approx 3500 RPM in 4th, a 1300 1302 was about 3700-3750 rpm in 4th. with a 1600 1302 gearbox its about 3150-3200 [email protected] and with a 1600 1303 box i dont know as i dont have one but i would suspect somewhere around 2900rpm @ 70mph(someone correct me?)
Just swap the nose cone for a 2 bolt one, it's easy.
