You'll need a new set of engine tins as the 1200 ones are different. Not sure if that's all of them, but I'm sure someone on here can clarify.
The flywheel should fit ok, as yours is a '72 and is 12v anyway. The 1200 box is fine and you'll see a good improvement in accelleration, though you won't see much difference in top end speed. You might want to think about a higher geared box at some point, but for now you'll be ok.
