1 - 20 of 21 Posts
For sale a new 1641 long block with guarantee. Spec as follows -
New 69mm crank (std)
New engle 110 Cam
New double thrust cam bearings
New cam wheel
New cam wheel bolts
New set of barrels and pistons
New big end bearings (std)
New main bearings (std)
New push rod tubes
New gasket set
New heavy duty oil pump
New rocker covers
New silicone rear main oil seal
Refurbed 040 ported heads
New scat followers
New sump strainer
Uprated oil pressure spring and piston
New oil pressure switch
Option 1 - all of the above in a non-machined standard case £750
Option 2 - all of the above in a non-machined new case £975
Delivery/fitting available.
I fitted one of your engines yesterday for a customer & was very impressed. It picks up instantly on the throttle & runs nice.
It should be a lovely engine once it's bedded in & final tuned.
This is a man that takes a lot of pride in his work & gives good after sales help & advice.
Discussion Starter · #10 ·
Pete,
Thank you for your very kind comments.
See you soon.
Richard
replacement engine
when i had trouble with my engine, a new one was out of my price range after buying the car,( and getting ripped off :mad:) richard found a very good second hand engine for me, run,s very sweet, nothing is to much trouble for him, when i have more money saved this is the guy i will have to build a new engine for me,
sales help & advice. and his tea making skill are fine as well:lol:
thanks john
Discussion Starter · #14 ·
thanks john
I thought my tea was shite!:lol:
Thanks John, your a star.
Discussion Starter · #20 ·
Account
Account upgraded.
Can you replace the removed posts?
*MOD EDIT*
Thank you for the support (even if you were pushed ;))
If you top up your Member Sponsorship each month, you will be left alone to trade here and we won't get complaints from VZi Advertisers (like we did this time) ;)
Posts reinstated :)
1 - 20 of 21 Posts
