21 - 25 of 25 Posts
· Registered
The black/white wire is main 12v feed to headlight switcher relay. (Connects from light switch).
The white wire is one high beam (blue/white wire goes to speedo warning light).
As stated, the black/red will be brake light circuit which should have a 12v feed from the fuse block.
I would advise removing all those scotch locks, none should be necessary for stock wiring.
Any repair would be a better option IMO.
· Premium Member
I now have this diagram printed out(y) hopefully make it easier for my one brain cell I have left 😅
U.S. spec diagram is slightly more complex due to extra wires which your car won't have, but the rest is the same.
Let me know if you want the Euro spec. version of that diagram.
21 - 25 of 25 Posts
