Hi all I have a 1971 1200 bug running a 1600 twin port engine with a pair of weber ICT carbs all bolted to a 1200 gearbox and I've been fighting an over heating issue for a year now since I brought it.
Long story short, she is fine under 50mph, as soon as I go 50 mph of above the oil temperature slowly but surely gets hotter and hotter, the faster I go the quicker the oil temp rises but I've never allowed it to go above 130⁰c on my gauge and that's when the save my bug dip stick triggers the warning light.
Now some history, at first it had a solid deck lid and this would send the oil temperatures up to 130⁰c if I went over 50mph.
I now have a 4 slotted deck lid and that dropped the oil temperatures down to 120⁰C max at any speed over 50mph.
I've now fitted top stand offs and this morning (first drive with them on) the oil temperature only got to 82⁰c.
What is this telling me?
All tinware, seals, fan shroud cooling flaps and bellows are fitted and working correctly, the carbs are jetted a little on the rich side but all carb adjustment settings are still with in spec.
No rubbish is in the cooling fan, dog house parts are all there.
I don't want standoffs but if I don't have them fitted I over heat, please help
PS I have a SVDA distributor fitted and I've tried timing settings from 28 to 32 BTDC but it made no difference to the oil temperatures and I'm running nine a 30 weight oil.
I also have 45psi @70⁰C oil temp @ 2500rpm so oil pressure seems OK but any thing over 110⁰C oil temp does bring the oil warning light on at idle
Cheers all
Cheers all
