441 - 460 of 472 Posts
· Registered
Discussion Starter · #444 ·
are the breaks ok now? x
They seem to be. A mate suggested it could be the smell of spilt brake fluid burning off the calipers. The smells gone anyway so its a possibility. Fluid level is still at MAX and the brakes feel good.
· Registered
Discussion Starter · #445 ·
Bought a cheap rivnut tool off ebay along with 10 stainless M6 rivnuts so i can install the front airdam/spoiler. Seemed to do the job OK.
Automotive tire Wood Terrestrial plant Rim Gas
Skimmed the paint off the crease in the sliding door and welded a few screws on then used a claw hammer and a bit of wood to pull the worst of the dent out. The bit right at the end of the door was too stretched to get the dent completely out so its got a bit more filler in than i'd like.
Automotive lighting Automotive tire Grille Hood Bumper
Bit of primer.
Automotive lighting Automotive tire Grille Hood Motor vehicle
Some topcoat. The last of my cans of VW Marine blue. Horrible match from this can. :rolleyes:
Automotive lighting Rectangle Automotive tire Automotive tail & brake light Bumper
· Registered
Discussion Starter · #452 ·
Had the starter fail again this morning. Just a click from the solenoid. Battery still registering over 12.5v. Figure its the old solenoid quit. I think i've possibly got a spare somewhere in the garage. Could just be a loose 50 terminal cable though.
· Registered
Discussion Starter · #454 ·
Found a place locally that will replace the braided copper cable. Everything else looks pretty new inside (its about 10 years since it was rebuilt) so looking at about £50 and i get it back in a couple of days. (y)
Looking at £125-150 for a chinese built one on exchange if i replaced it so i'll keep this bosch one.
· Registered
That’s still good value last time I priced a new one was over £100 and that was 9yearrs go maybe, surprised they hadn’t gone up more! I managed to get a cheap one at the time that wasn’t exchange but always meant to send mine for s rebuild.
· Registered
Discussion Starter · #460 ·
Driving my caravelle this morning, large backfire, revcounter needle dropped to zero (engine shut off) but as we were still travelling along it restarted before another huge backfire and the engine shut off again. Pressed clutch in and coasted to a stop for a look.
Couldn't find anything wrong so restarted and drove on.
This afternoon i checked spark plugs, still clean and gapped correctly, leads were new a year ago so popped dizzy cap off and the centre pin fell out. I assume that was the reason. :unsure:
Couldn't find my spare cap so robbed the one off my beetle and it fired straight up. Rev counter needle stable at idle (it wavered about a bit this morning) and it sounds like its running smoother. Hopefully thats sorted.🤞
Motor vehicle Automotive fuel system Auto part Vehicle Gas
