Hi All,
I'm having problems with the Brosol carb on my engine - it's shit. It seems to give too much fuel on choke, and seems to get leaner as the engine gets hotter (making the engine run hot - it's the only possible explanation for my engine running a little bit warm)
I was thinking of replacing it with a stock carb, partly because of all the bad things I've heard about Brosol carbs...
Is a 31 pict 4 OK for a 1300 TP engine - it came off an AB code engine but my GSF catalogue seems to suggest it is for a 1600.
If not, which carbs should I be looking for for a 1300 Ab code engine.
Thanks in advance :)
Whats wrong with yer carb?!!!!
My 1200 runs perfectly on the Brosol carb! Better than it did on a stock one! It'll touch 70 too ;)
