1 - 1 of 1 Posts
massive 'big' pistons
-44 and 36mm
-they could be off a s4 928
no pads or clips - link pipes need doing
-and also need 4 bolts
two 44 mm seals are not present
-all the pistons are and they are all free and schweet
cheap massive 2 piece radiall mount porsche calipers for 305 by 32mm discs - use spacers on a skinny disc
-or simply run the 305 by 32mm -80mm offset s4 928 discs on a cut down bug drum, drilled pork
make an easy radial mount adaptor
-cheap at £125 the pair
-plus 1 986 rear £90
one 996 rear £100
964 front 40mm and 36mm pistons £45 -36mm piston missing
0774 858 2044
-postage will be 25 quid
cheque is fine
-a
1 - 1 of 1 Posts
