Hello there
I have had a good search around and I cannot find a good thread regarding re-aligning door pillars when they have rusted and and being repared. I currently am at the stage of trying to align the door in the aperture (was correct before) and I am having little luck in find a good place to weld the bottom of the repair panel to the heater channel.
I can get the door to hang squarely in the aperture with the striker plate taking a lot of the weight of the back of the door, but it obviously sags when opened as the bottom of the A post is not welded.
I had planned on closing the door using the striker and making it sit (using the swage line for reference) a few MM higher than normal. Then tacking in the A post from the inside and trying for fit, then grinding out and repeating if nessesary. I would make it sit a few MM to high to allow for slight flex in the body and hinges etc when the weight of the door is released.
How does everyone else do it? Does this seem like a good method?
My car has had the channels replaced but the alignment of the door in the aperture was good and all of the gaps were very even. It even had that slight "clunk" like you hear in the ads of the period (with the quarterlight open of course
Many thanks and I look forward to your replies!
