im trying to get a grip on photoshop7.Is there a function on it that allows me to add text to a pic?Then turn it into a stencil?
DarrenW said:
You can add text to a pic with the "type" tool, it's the one that looks like a letter T. Not sure what you mean by "turn it into a stencil" though?
you could emboss the layer......dont ask me how though.....its not the sort of thing i use photoshop for!
snide twat
nefarious said:
Do you mean simplify the image so you can cut it out a la hoodride stencil?
Quick and dirty method would be to 'posterize'... theres no guarantee it will look good first time... you may need your photoshop skills to tweak it first before posterizing.
what he said :)
dropping the number of colours helps too, change to sixteen colours then mess with the contrast, then drop it to 1bit (two colours) and tidy it with the eraser. you don't need to get it exact as if your printing to use a stencil, you can correct the jaggedy-ness when you cut it with the knife.
e.g:
jaggedy print:
cafeful cuts:
leads to:
