1 - 2 of 2 Posts
I think thats what they are
On the front upper and lower beam there are things welded on with a nut on top and a nut on the face. When you undo these nuts there is an allen key bolt in the facr of upper and lower.
Do i just lift the car off the grond, undo the nuts upper and lower and then unscrew the allen key bolt ( i want to lower it) and then re tighten the nuts.
If so how low can they go an how do i know if ive gone to far on the adjustments or can i not go too far.
Is there any way through adjusting that i can knacker up the beam?
Basically- How do you adjust the height of the car?
Alan
1 - 2 of 2 Posts
