i just got back from swindon and purchased some new head lights for my split off alan schofield. they came with new halogen h4 headlamps but when i put the lamps inside the actual head light, the h4 stamp on the head light is sidewards? is this supposed to be right? also when you sit the lights beside each other, both side lights are in the bottom right hand corner? are these head lamps not sided????? please if any one can help me shine some light on the matter that would be great, or if im confusing you then just let me know and ill see what i can do :hangloose cheers all
the position of the side light bulb is correct - the lamps aren't sided.
As far as H4 logo being sideways - sounds like you have bug units.
you need to dismantle the headlight (couple of screws) rotate the lamp through 90∫ and re-assemble. The way yours are set up would be for a bug where the whole headlight is 90∫ to a bus (they're more or less the same unit).
Do one at a time in case you get stuck, and remember to rotate one clockwise and one anticlockwise or you'll end up lighting up the sky!
Öbtw, wasn't it Slough not Swindon?! :D
