61 - 80 of 107 Posts
Well I am about ready to push this bloody car off a cliff.
Brakes are driving me crazy.
New master cylinder.
new front calipers
new rear shoes
bled the brakes, pedal still goes to the floor.
must still have air in the system, bled them again...pedal still goes to the floor.
no leaks that i can see.
Cant work it out
what am i doing wrong. :(
Tony
I've had trouble in the past getting all the air bubbles out with the up/down pedal approach.
Using a pressure fed system like ezibleed really helps shift the stubborn bubbles.
Calipers can also retain a little air pocket so try removing them, hold the brake pedal down and crack the bleed nipple whilst moving it around.
Does pulling up the handbrake give you any pedal improvement?
If it does you need to re-adjust the back brakes.
It could be faulty seals on the new master cylinder, but if you can get "some" brake pedal by repeatedly pumping the brakes I would doubt this was the cause and definitely points to air trapped in the system.
Discussion Starter · #62 ·
Car Vehicle Hood Plant Sky
Wheel Tire Car Land vehicle Vehicle
Brakes working better now that I have adjusted the rear shoes, need bleeding again still.
Fuel tank in, need another filler neck as the one I have is the wrong one...typical.
Wheels back on so I can push it round.
Might need to raise the front a touch as I am nearly on the front bumpstops.
馃檪
Tomorrow I hope to finish hacking the bumpers about and get the mounts sorted, then fill and sand the body ready for paint...Eeeeep
Tony
Ps.
It has changed a bit in two years.
Car Wheel Tire Vehicle Plant
Car Tire Wheel Land vehicle Vehicle
Wheel Tire Car Vehicle Plant
Discussion Starter · #64 ·
Well a trial fit of the cut down front bumper.
Side mounts drilled in the right place I hope.
Don't look too bad.
I can finish the bumper now I know it fits.
Tony
Vehicle Car Motor vehicle Automotive lighting Automotive design
Wheel Tire Car Vehicle Automotive parking light
Tire Wheel Vehicle Car Hood
Discussion Starter · #65 ·
Well it has rained on and off for three days now, but I have managed to get the bumper shaped better.
It now flows round the shape of the nose better now...I think anyway.
Tony.
Vehicle Motor vehicle Car Automotive design Automotive exterior
Vehicle Car Land vehicle Automotive lighting Motor vehicle
Discussion Starter · #67 ·
Thanks.
Been filling and sanding all day today.
sore arms and shoulders.
for a small car there is a hell of alot of sanding to do.
Tony
Discussion Starter · #68 ·
Morning.
Off to try and sand my roof today.
Still waiting for fuel tank parts so I will carry on getting the body ready for paint.
Tony
Discussion Starter · #70 ·
Didn't sand the roof in the end.
found more sanding to do on the rear wings, oh well.
I think I am ready for hi build primer now... I hope.
Tony
  • Like
Reactions: Cat
Discussion Starter · #71 ·
Spent most of the day gardening
馃檨
馃檨
Did manage to finish fitting the fuel tank plumbing.
Ho hum tomorrow is another day...not for gardening I hope.
I will take some more pictures when something actualy happens with the build. ;)
It just seems to be endless little boring jobs, got more wiring to do tomorrow...I hope.
Tony
  • Like
Reactions: Cat
Discussion Starter · #72 ·
Well the headlights now work
The indicators work
Screen demister controls all made and conected up.
What a pig of a job.
Need to make a relay mounting bracket next and then I can get on with boxing in the back of the dash.
We plod on slowly.
Tony
The indicators work
We plod on slowly.
Tony
they had screen demisters!!!! i always have the quarter light open in my bay to stop the window misting up :ROFLMAO: :p
Discussion Starter · #74 ·
I am not saying that they work very well, but yes they have screen demisters. ;)
Tony
Discussion Starter · #76 ·
Gave up with the horn today, will tackle it when I am in a better mood.
So instead I finished making up the wiring covers,
Ok they are not great, but once covered they should look tidy.
Tire Wheel Automotive tire Hood Vehicle
Tony.
Discussion Starter · #77 ·
After fighting with the horn yet again...I give up.
Decided to fit a button instead.
As my ignition switch is in the dash ( could not aford an original switch)
The horn button has been fitted into the ingition switch hole.
Automotive tire Light Motor vehicle Steering part Automotive design
Yes it is not original and the purists will have to live with it. :)
But it works...AT LAST. :)
Tony
Discussion Starter · #79 ·
Steering wheel painted and slotted in place.
Dash almost ready for painting, just need to sort out the glove box latch.
Trial fit of the upgraded wiper motor, I need to fettle it a little bit more still.
But it looks like it might work.
Speedometer Vehicle Odometer Car Motor vehicle
Speedometer Vehicle Gauge Car Gear shift
Motor vehicle Electrical wiring Auto part Gas Cable
Tony
Discussion Starter · #80 ·
Well after lots of faffing about and fettling, the golf mk2 wiper motor fits.
I got slow and fast speeds, just need to sort the parking now.
Just about ready to start masking up the body for spraying with high build primer.
Got my daughters wedding next week, so nowt will be done for a little while now.
still I could do with a break from car restorations.
Tony
