1 - 14 of 14 Posts
I've been making do with fashioning sheet metal parts by hammering them over a 5" vice and bits of timber, but it's reached the point where I think I need something a bit better for battering things flat and making sharp folds.
So the price of anvils has shocked me a little. I thought they'd be things people would be trying to get rid of, but everything used seems to be £200+. Looking at new ones I can get something around 10kg, with a 10*20cm ish surface for around £50 (VEVOR Pro Horn Anvil 22LBS 10KG, Weight Steel Anvil Blacksmith 360mm Length Blacksmith Anvil, Portable Rugged Cast Iron Anvil Blacksmith Anvil Stable Workbench Blacksmith Forge Anvil Tool, Dark Gray : Amazon.co.uk: DIY & Tools). I also recall people saying length of railway track is useful too, but that seems to be £50 for 250mm so it's no cheaper.
Has anyone got any advice about whether that is too small to be useful? Is 10kg heavy enough? I don't know what I'd use the 'horn' part for, but you don't seem to be able to get anvils without that.
Theres some old lengths of railway track in the old quarry just down the road from me. Not sure i could sneak a length out of there without crippling myself though.😁
A few anvils are usually available on facebook marketplace. This is just £35 near me. 8.5" long (about 215mm) old rail track from the look of it.
Probably a bit heavy to post.
Plant Outdoor bench Wood Street furniture Outdoor furniture
When I googled I did find that network rail sell off old track and sleepers, etc. Trouble is they only sell in multiples of 000 tonnes. It's tempting, but I don't know how quickly I could cut 1M kg of railway line into chunks with a 4.5" grinder and ebay it all. 🤣
Marketplace has 2 anvils within 40km of me, both >£500. The first one under £100 is the one you have pictured! Only a 10.5h round trip.
A heavy duty RSJ should keep you going for a while.
A short length (<1m) is around £30. Have word with a builder and you might get an offcut for beer money.
This is what I use. Coke bottle for scale
Road surface Asphalt Bottle Gas Font
I honestly don't think I could be without it, it's in daily use.
I bought it off eBay. The delivery driver made me pick it up from his van as he couldn't lift it! Lol
I do have some railway track (from Severn Valley Steam Railway) but I can honestly say that I've never used it. You are welcome to it free of charge, but I'm not posting it!!!
I also have a collection of round offcuts I've got over the years from machine shops, usually in exchange for a bit of welding etc.
Dishware Tableware Serveware Automotive tire Gas
Would something like an old cobbler’s last work ? You could probably pick one up for a tenner at an antiques place
Natural material Wood Art Creative arts Metal
Or try your local scrappy ? They might have offcutts of steel which would suit
Oh, big thanks to gojira. 👍
This thread got me thinking about heavy duty pieces of metal that you might be able to use. I remembered I've got a large Victorian garden roller that's dumped in a field awaiting collection. I was waiting until I had a van or estate to move it and get it sold. I've currently got an estate. 😁
Discussion Starter · #10 ·
🤣 No worries. RSJ is a good shout. There's some local for around £25 for a 2.5m length, but that's too long and heavy to fit in my van. I'm sure some more will turn up in a suitable size.
If it's got the right profile for your needs, I'd be tempted to stick it in the van with the back open, lash it down (or get a fat mate to sit on it😁) and wrap a hi viz around the end.
To get the size you want, you need an offcut of a big RSJ. A small, uncut one, will have a smaller cross section, as it's used to span a smaller opening, supporting less weight.
Plus, if it's 2.5m, you can chop it up and create different, common angles you may need. Or weld it into a box section, for bending heavy gauge.
Saddest VZi'er 2020
10kg would be the absolute minimum I’d say. 25kg would be better.
As a comparison, a 1ft length of railway line will weigh about 20kg.
Mine is quite small, by industrial standards, at 1.5 CWT (168 lbs, a little bit over 76 kg), and as it’s barely worn it’s easily £500 worth.
Anvils have always been expensive, and generally valued by weight. My dad used to say “ten bob a pound” as in lb, and he’s been dead thirty five years. These days I doubt that you’ll find anything that’s not worn to buggery for much less than £2 a pound, and maybe nearer £3 or £4 i bought from a dealer. You’ll pay more again for one with a proper stand.
  • Like
Reactions: gojira
How much!
We often have 3-400 tons stacked in our scrap area. Trouble is, the shortest length in there is 60ft & weighs approximately 1 ton.
Anvils are generally used for working hot bar after being heated in a forge e.g. blacksmithing.
If you are working sheet metal, you’d be better off with stakes, dollies, hammers, folders, shrinker/stretcher. :)
1 - 14 of 14 Posts
