Any Burgular Alarm Fitter in Da House
572 views 2 replies 3 participants last post by  subdub
#1 ·
Got a door break/sensor in place but no door there anymore and could do with fitting a motion sensor instead - will this just wire onto the existing cabling? and just replace it?
I kinda think it will but my regular sparks doesn't do alarms:(
#2 ·
There won't be a 12v feed to a door contact which you will need for a PIR, there should be enough cores in the cable, but you'll have to go into the panel, locate the cable and connect a 12v+ and - to power the PIR.
You can use the same zone, and there should be a pair for the tamper as well.
