1 - 9 of 9 Posts
got a prob with heat plugs getting no
power
but cant find a fuse or relay for the plugs anyone got any idea
where to find them if they are in with summat else on the fuse board
How do you know that there is no power to the heater plugs?
To test, remove the supply wires from *all* of the plugs and turn on the ignition. Using another length of wire connect each plug to the battery positive terminal. There should be a spark if the heater plug you are testing is working and drawing power.
Be careful and make the test connection for the shortest possible time.
Sorry don't know enough about the Isuzu to direct you to the fuses (but should be idenifiable from the list inside the fuse box lid) or the timer replay.
Hope none of this has been an egg sucking lesson :)
What year is it, ive got a 'genuine' workshop manual for a trooper from around 1992, its the real deal not a crappy haynes.
no mate tested for power and not there so looking for fuse or relay
which cant find on fuse carrier lid
Deepdale said:
Try this:
http://www.itocuk.co.uk
The Isuzu version of VZi...Helpful guys.
We use the Mitsubishi version for fixes for our trusy old Pajero, so i'll put that up if anyones interested:
http://www.pocuk.com
:hangloose
cheers its not a masive one its only a 1700 corsa combo
so dont know if that site could help but will look on off chance
thanks for the help guys :hangloose
I really must get out more
it is on the left hand side in the engine bay under a rectangle box
1 - 9 of 9 Posts
