Anybody tried these....
901 Views 14 Replies 6 Participants Last post by  MrG
Looking at getting some new heat exchangers for my bug, and I've come across some in the Cool Air catalogue they're calling the "Ultra Heat Exchanger Kit".
Kit goes for £200, as opposed to £45-£60 per exchanger from the other usual suspects, so they're a bit dearer.
Claimed features:
- Powder coated for corrosion resistance.
- Large aluminium heat sinks (supposedly 15-25% more heat)
- Laser-cut exhaust flanges for positive seal.
I can't find a link to this kit on their website, but it's in their 2006 catalogue.
Just wondered if anyone's used these and got an opinion on them. Any improvement or just hype?
1 - 15 of 15 Posts
imo the powder coating is a good idea. but not sure about the extra volume for heat. reason being that the original size heat exchangers pump out the heat when correctly fitted anyways. i personally wouldn't pay out the extra £100approx for it. maybe look at how much it would be to get originals powder coated? i guess it depends on how long yr intending to keep the car for as well :hangloose
Having larger heatsinks like the original German ones had is a good idea as it kicks out more heat, but I don't think it warants doubling the price! Laser cut flanges?...I use a large file to give 'a positive seal'. I keyed up the paint with some wet and dry then sprayed my after market Danish ones with black heat resistant paint and 3 years later there's no rust on the outside. The rocker boxes tend to keep them rust free :) Next time I'll go for J tubes to preserve my heater channels.
You can't get larger heat sinks than with a Genuine exchanger. So, if these are aftermarket, then 15-25% better than other aftermarket isn't enough. They maybe Dansk (or similar) heaters which have been powder coated, and those were never that good anyway.
Are Genuine ones still available ? if so what is the current price ?
The ones Heritage list at £59, can't be original, (or can they ?)
I believe they are still available, but not at £59!
They do come up for sale at various times, but this year it took me 7mths to find a NOS pair.
They were also a lot more than £59ea
Good luck
I doubt VW have made them for 20 years, you can pick up genuine ones second hand at shows - you can tell genuine ones because they're a lot heavier and the fins inside are properly formed and long, not blobby. My Dansk ones are fairing well and do give out heat, but don't scold my ankles :)
Phatman said:
I doubt VW have made them for 20 years....
Yes, they have been available, at least up to the last few years. I will see if I can find out.
I've seen Mexican ones advertised, but I understand that they don't have any heat exchanger fins in them, (warm climate equipment). I also have been told that there are some which are a different shape, and may only fit the Mexican Fuel injected engine's exhaust system. All very confusing :rolleyes:
Laurence Fletcher said:
I've seen Mexican ones advertised, but I understand that they don't have any heat exchanger fins in them......I also have been told that there are some which are a different shape, and may only fit the Mexican Fuel injected engine's exhaust system.....
That is correct. Mexican heat exchangers are effectively J-tubes inside the casing. It probably has more to do with the cost than anything else.
However, there is no difference between heaters on a Mexican FI engine and the carb units. There is a big difference on the old US/Canda/Japan 'AJ' FI engines.
I forgot to mention that the Mexicans could purchase the 'proper' heaters at their dealers, if they wanted to.
Thanks for explaining the FI exchangers.
So up to recently, VW Mexico were still making 'proper' heat exchangers as an Original Accessory. Those would be the ones to find, but probably extremely expensive, :eek:
....So up to recently, VW Mexico were still making 'proper' heat exchangers as an Original Accessory.....probably extremely expensive...
No, I think they are German made (or somewhere near by). They are expensive, costing nearly six times as much as the non-finned type!
Thanks for the replies guys.
I think I might go for the cheaper ones and then maybe paint them myself and see how I get along. Can't wait until a pair of NOS exchangers come up at a show - it's starting to get cold now! :)
1 - 15 of 15 Posts
