Anyone got a photo of a mid-seventies bay accelerator linkage under the front of the van, between the chassis rails and above the bolt on pan?
I need to know what angle the part that joins the cable should be at when the pedal is fully up :)
it sits against a stop :confused: the cable pulls the arm back to a little stop thingy everything is held together with press in pins :confused:
This linkage is different to all the other bay's I've done work on (in this area) - the part that the cable attaches to is lying back against the underside of the cab floor when the linkage is "relaxed"
The part that comes from the pedal to the rod that goes across to the centre of the van has been replaced with home brewed components and I don't think it is positioning the linkage correctly, resulting in insufficient travel. I want to be sure of how it was set up originally so that it can go back that way :)
