1 - 10 of 10 Posts
I'm having a nightmare trying to print a photo.
It keeps coming out in the wrong colours and the contrast is way out too.
Here's the photo:
And here's a scanned copy of what the printer managed to print off:
Any one got any ideas what's going wrong here?
It's an Epson Stylus colour 460 with brand new ink cartridges. I've done all the usual head cleaning/alignment/test prints etc etc and they're all fine.
Administrator
There's no CYAN in that pic (or the BLACK, MAG and YELLOW are pushed way high)
There should be a 'control panel' (on screen) where you can set ink levels . . .
I'd leave the BLACK at '0' and knock the rest back to '-20' then try again
You may need to push the CYAN till the pic looks 'right'
Good luck
Bri
Good luck
Bri
Cheers Bri :D
Blocked cyan ink jets... no amount of head cleaning will shift it :(
Looks like a new printer could be on the way.
Administrator
You can take them off usually . . . and soak them in boiling water
Try it ;)
Try it ;)
I'll give it a go but usually my tool weilding skills rest with a hammer and big spanners ;)
Administrator
I don't know the model . . . but often they're held in/on with baby 'allen' bolts (watchmaker sized :eek: ) . . . while others just 'clip' out/in
Good luck
Bri
go into paint on your pc click print then preferences then you can clean your print heads and do a test print make sure your set on the right grade of paper good luck
1 - 10 of 10 Posts
