they fit, in as far as they are the same PCD (5x112)
they have a smaller centrebore though, so you will have to have the wheel centres bored out to clear the dust caps on the front.
You will also likely need to fit spacers depending what width and offset you get. And also longer studs on the rear, and use longer bolts on the front (or fit conversion studs).
Once you know what wheels youre fitting, have a look on the brick-yard in the forums, specifically the aloy wheel forum.
Studs, nuts, spacers etc. are all available from www.brickwerks.co.uk
i have S line audi wheels on my t25 7 1/2" x 16"
i had to get the centers machined out to clear the bearing caps at the front, the rears are OK, i couldn't use the center caps though
you'll need to be sure of the offset, and the width
ar the rear if they are too wide and depending on the offset, you might need to extend the sliding door hinge
