balancing carbs
542 Views 7 Replies 5 Participants Last post by  clarkson
wha kits needed to balance twin carb setups and whats the procedure??? anyone know or got any advise??
fanks!!
1 - 8 of 8 Posts
Was'nt there a how to in last months volksworld? Had a few pages on setting up with different airflow meters.
It might have been the month before actually.
What carb setup / linkage have you got?
Basically you need an air flow meter (£15 from halfords) to make sure they open the same on both sides. Basically if one opens more than the other the engine will be fighting against the other side. It is amazing the difference it makes.
hi there! it'll be kadrons on single port manafolds, can you use a vacuume guage??
Better with one of the "snail" air flow meters.
And don't forget to undo your linkage when setting them up.
is there a basic how to anywhere??
1 - 8 of 8 Posts
