i have a problem with my steering on my bay, about a week ago i started to feel the steeering tightening up but only intermintently and not constantly while turning. then the steering went completly stiff. i was able to turn the wheel a full turn and after that its not possible to turn it at all unless you happen to be a body builder. i automatically assumed that it was the box as this was where all the crunching noises was coming from. i have started to attempt to remove it but am i right in thinking this is definatly the problem, what else should i check before going any further? could the crunching noise in the box just be because its straining against something else that has jammed in the steering assembly? thanks in advance for any help :)
Discussion Starter · #2 ·
and its a 72 so whats the easiest way of telling whether its worm and roller or the earlier type? thanks
thanks, ill give that a go tommorow. pig of a job getting those pressed joints apart, pullers are bloody useless :rolleyes:
