Im starting to build an engine and am struggling a bit with what size bearings i will need.
firstly my big end bearing:
The journals on the cranks all measure around 55.02 . IS THIS STANDARD OR HAS IT HAD A GRIND?
Secondly the main bearings:
The journals are all about 54.75, IS THIS STD OR HAS IT BEEN GROUND?
Any pointers or information on the bearings i need will be greatly appreciated :)
P.s. i know the outer diameters
big end diameter = 54.98-55.00mm
Main bearing Journal diameter 1,2 and 3 = 54..97 - 54.99mm
Main bearing Journal diameter 4 = 39.98mm
regrinds are available in 0.25mm/0.5mm/0.75mm under size
by the looks of your mains i would say its had a regrind to 0.25 undersize or it must be worn as hell!
