1 - 8 of 8 Posts
A Baja is well under way now and I was wondering if anyone had a good setup that didn't throw the speedo out to much?
Ta
Jon
Depends on how high you want it, gearbox spec, suspension, bodylift etc
31/10.5/15 common rear.
I put 35/12.5/15 on the 1 I built but has a 3.5" suspension lift.
Speedo is driven from front so again all depends on how high you want it to look.
3.5" is about as much as I want and that size sounds good, any links to useful sites matey?
Parts wise?
Ta Jon
P.s won't be going that fast as its an AUTO!!!!!!!!
A good tyre size for a Baja will throw the speedo out. But I did the calculation on mine and found that my speedo will read 10% under, so I add that much to whatever speed my speedo is showing. You get used to it quickly and do it automatically.
1 - 8 of 8 Posts
