OK, anyone got a cunning trick to remove the starter motor bush (12v bug) without removing the engine? (Yes I know its only four bolts and you can do it in 4 minutes, but there has to be a neater way)
Run a tap into the bush and then thread a long bolt in and pull
it out. The bush is usually not tight in there.
(I can't tell you what size tap to use because we still
use those awful inches over here :D
