Having major troubles getting Flywheel off.
2" * 1" square steel tubing bolted to clutch bolts has bent, not strong enough.
Can you split engine, and rebuild without taking flywheel off.
Not fussed about re-shimming and all that, just want inside cleaned out, and replace big end bearings.
Reckon work i need do is mains, big ends, clean out, 1 conrod and back together.
Can i do this with flywheel on.
All pistons/conrods are now off.
cheers
cheers
