I've been rebuilding my engine and I've finally got the engine working again, but the problem I had when I started all this is still there.
The car idles fine until it warms up and then it dies. I've tried increasing the fuel, adjusting the bypass but they dont seem to make any difference.
I've replaced all the gaskets, piston rings, set the valves, replaced the points and condenser, re done the timing, replaced the dizzy, rotor arm, coil, cleaned the carb then oiled the moving parts. All to no avail.
I'm running out of things that it could be.
What about that little thing that goes into the side of the carb? Any other ideas?
Its a standard 1600TP.
