1 - 9 of 9 Posts
I have a 1679cc with a Weber progressive carb. I just rejected it to some specs from a guy. I installed on the idle 50 from 60 on the main. On main jets 137 to 125 and 180 and air jets 160 n 180. I got it running and it idles smooth but now when I rev up it still has a slight hesitation that I just can’t get out n on the idle back down a small pop sound from the exhaust. The reason I changed the jets is because for it to idle smooth the mixture screw had to be closed n I know that ain’t right. Now I’m not sure where it’s at but questing it’s maybe a turn or so out which is better than before. So any ideas on what I need to do. Oh and the 88mm pistons are thick walls with the 90.5mm heads on it.
So if you mash the throttle is there a flat spot.. This can be a single carb thing. The carb is too far away from the plugs. Twin carbs don't do this as a rule. Are the pre heat pipes hot. Is the manifold under the carb cold. A 009 dissy can cause hesitation too. You could try 1 size smaller idle, but the smaller you go the more chance of it getting blocked. Check the colour of the plugs after a run
You may have already come across these, but another two helpful web pages on the matter:
The second talks to air-fuel ratio adjustments (calibration) at the bottom, regards correct number of turns and jet sizing.
I've just fitted one to a new (top end build) 1641. I've followed the jetting advice of the link DK Bug provided, as a starting point. I've tried also to find a preheated manifold (in the aircooled link) but they're v hard to locate nowadays. Others run a pipework/hosing from the exhaust side of the tinware to the air filter inlet to compensate, for limited heating from a standard preheat manifold. I've not taken that route as a start point, but I've also not started my engine yet.
Linkage is an ass with these too, I've fabricated/bodged this (home build style)
Motor vehicle Automotive tire Gas Auto part Engineering
As I say, not fired mine up yet. Given the stories you hear of running/tuning these carbs I'm as nervous as I am excited about the day I turn the key - v soon now.
Good luck with your endeavours.
It didn’t have this problem before I changed the jets but that’s because the mixture was closed off and according to specs it needs to be 1 to 1.5 turns out. Yes the heat tubes are hooked up. Had to modify my Baja exhaust to get it to work.
I am not an expert on the issue, but as I have been thinking maybe to fit a Weber progressive to my engine, I have done some research and came upon this article.
There seems to be some well founded suggestions in there.
Making the Weber Progressive Carburetor (32/36 DFEV) Work on the Aircooled VW Engine | VW Parts for Aircooled Volkswagens - Aircooled.Net
that’s where I went n got the information for changing the jets.
Thanks I’ll look into it. I had one on my old Baja I had yrs ago. It was a 1600 stock. And it worked like a champ. Almost pop the front tires off the ground. I’m thinking maybe the older carbs where built better then the new ones.
You've ran it rich with bigger jets. Now that you've weakened it off with a smaller jet, it's exposed a hesitation. The hesitation is either lack of fuel or a cold manifold etc. You say the pre heats work, so that leaves a lack of fuel. You might fix the hesitation with a bigger pump jet. You could use a micro drill bit to enlarge the 1 you already have.
Well I got it a lil better what I did was opened the mixture screw some more the hesitation is better but I can smell a lil gas as I rev it up n it comes down. I know vw engines need a lil rich to run cooler If this doesn’t get better I’ll try your way.
1 - 9 of 9 Posts
