Sounds like a late car made to look like an early one. The plastic dash will come off easy enough if you really want to remove it. It might even have been added later on. Try to check if the car has been swapped from LHD to RHD (or vice versa) as sometimes they put a plastic dash on to cover up the welding work left behind when the dash is swapped over.
Try to find out a bit more about it....
I know someone who worked in the Caymans for three years, and they said it's hardly worth having a car - the island is not big.
